[SOLD] Gaerne SG22 boots size 42
Gaerne SG22 Size 42. $300?
I bought these and did a little week long tour in Vermont with my wife, and a little testing here before they, but they don’t quite fit my foot as well as my other boots, so I’m selling them. They’re amazingly well designed top-of-the-line boots made in Italy, but they just don’t quite work for me.
  • Generous toe box
  • Dual stage mechanical pivot system for great flex
  • Mechanical hinge has two settings that limit range of motion to prevent hyperextension and hyperflexion
  • Three-dimensional toe box construction allows for reduced height between the sole and rear lever for improved shift speed
  • Gaernes outstanding Internal memory foam has been redesigned to better fit the shape of the ankle and increase support
  • New sole design features an improved shock absorber and some lugging for more grip
  • Newly designed Razorback for reduced weight
  • Goodyear Welt sole construction
  • Steel Bumper for toe
  • Superlight aluminum buckles
  • LOTS OF ADJUSTMENT FOR CALF CIRCUMFERENCE: Buckle location can be adjusted to three positions, AND shin guard has two position to optimize fitment for knee protection
  • Dual Air Vents allow air circulation to prevent humidity and heat buildup
  • Heat Guard on inner leg features rubber designed to improve grip of bike and feel
  • Dual density sole inserts and microshock heel
  • Steel toe cap with reduced thickness and weight
