So I’ve had this scooter for a couple of years. Rebuilt the carb when I got it, use fuel stabilizer and Sea Foam on every fill up, and did a bunch of other things to it.
However when it is cold or sits for a few weeks I need to finagle the throttle to get it to start. Then it runs fine when warmed up, but that hard start has me scratching my head. Idles fine ones running, but in order to get it there, I need to rev it past 2k on the hard start ups.
I can’t find a vacuum leak anywhere, and it didn’t run before the rebuild so I have nothing to compare it to.
These don’t have a manual choke, they have a system that uses a wax substance that “closes” the auto choke system once it’s warmed up.
If anyone has a clue I’ve scoured the interwebs and can’t find a straight answer that isn’t fuel/air/spark related. Just seems like if I had a manual choke it would start fine but I can’t locate good info on the auto choke system these have.
Trying to save some gas since it gets 60-65 mpg ![]()
