690/701 tuning
Been a while since I’ve got on here. Sorry about that!!
As I haven’t ever done anything with tuning, I decided to dump some info into our AI Overlords and see what it could spit out. I wanted to run these tables past people on here to see if there are any call outs. For reference the bike is a 2023 701. Running a Rade intake (open), Tekmo header, PowerCommander 6 with Autotune and a Map Switch for the PowerCommander. Currently the map only changes A/F ratios. Map 2 is a spice map already. Why do this? Well because I can. Should I? I don’t know. Keep in mind, the PC6 “piggybacks” on the factory stuff. So it’s adjusting on top of what factory is doing.
Map 1 items in the pictures.
Map 2 (or Power) map. Of interest, AI took the AFR down on the power map from where Dynojet had it. Apparently the theory was to let the fuel adjust do more and let the O2 do less?
