As long as we’re on the topic of the service at local KTM shops, I had an “interesting” experience with Fay Myers recently.
@Arrivo and I have been having conversation about me buying his 790. I wanted to have the cams inspected first, to at least get eyes on them. I took it to FM and said “I want the valves checked and cams inspected.” Received the work order via SMS the next day. Mind you, I brought the bike down with the tank and all body work off, as we had been doing some other things on the bike.
Work order showed $500-700 for the valve check (don’t recall, but that seemed kinda reasonable) but ~$9xx for the cam inspection. Insert record scratch sound effect.
After some texting back and forth, it was clear that “inspection” in KTM speak = a 3rd party process that apparently involves an electron microscope and MRI…or some shit.
Called up the service dept and basically laid out a flow chart for them:
- Remove valve cover, measure valve clearance. In spec? Take pics of what you can see of the cams, send pics to me. Replace valve cover, done.
- Out of spec? Remove cam bridge, remove cam(s), place cam on bench, remove phone from pocket, photograph cam, send to me. Adjust valves, reassemble, done.
That’s it. I was clear to redefine “inspection,” as “send me pics of the cams.”
I went round and round with them for, no shit, a week, trying to get them to do this. They wouldn’t budge. I eventually said F it, picked the bike up, expecting to a get a bill for the text and email conversations.
My sense is they’ve been round and round with KTM and 790/890 cams enough to now have a process whereby they get $$$$ from the customer on the front end for anything involving “inspect / photograph / put your hands on” the cams, so that if/when KTM denies a warranty repair, they’ve at least gotten some $$ for labor?
So, I’m going to buy the bike from the Steve and will check the valves and inspect the cams myself at the next valve check interval.
This was my first experience with any CO KTM dealer service center on a multicylinder bike and it was NOT confidence inspiring…
